Power consumption
Power consumption is moderate. Measured with power adapter Lenovo ADLX90NLC3A 20V 4.5A by Voltcraft 4000FR:
- OS idle: 9 W / 23 VA (low power factor, not very good).
- CPU stress:
7z b: 37-42 W / 41-46 VA.
- Youtube 1080p in LibreWolf v131: 25-30-41 W (similar to CPU stress, probably I have to configure hardware acceleration).
- Disk:
dd if=/dev/nvme0n1 of=/dev/null bs=10M: 28 W / 33 VA.
- 3D:
gamemoderun glmark2: 50 W / 55 VA.
hw-probe
Probe #3f2770b9fe.
Benchmarks
Some benchmark results.
OS = Devuan 6 Excalibur (testing), XFCE, X11.
# inxi
CPU: quad core AMD Ryzen 5 PRO 2400GE w/ Radeon Vega Graphics (-MT MCP-)
speed/min/max: 1600/1600/3200 MHz Kernel: 6.11.2-amd64 x86_64 Up: 2m
Mem: 1.17/30.3 GiB (3.8%) Storage: 238.47 GiB (14.2% used) Procs: 265
Shell: Zsh inxi: 3.3.36
# inxi -SG
System:
Host: devuan-home-nvme256 Kernel: 6.11.2-amd64 arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.1 Distro: Devuan GNU/Linux 6 (excalibur/ceres)
Graphics:
Device-1: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega Series
/ Radeon Mobile Series] driver: amdgpu v: kernel
Display: x11 server: X.Org v: 21.1.13 driver: X: loaded: amdgpu
unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
resolution: 1920x1200~60Hz
API: EGL v: 1.5 drivers: radeonsi,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-1 renderer: AMD
Radeon Vega 11 Graphics (radeonsi raven LLVM 19.1.1 DRM 3.59
6.11.2-amd64)
API: Vulkan v: 1.3.290 drivers: N/A surfaces: xcb,xlib
% gamemoderun glmark2
glmark2 2023.01
OpenGL Information
GL_VENDOR: AMD
GL_RENDERER: AMD Radeon Vega 11 Graphics (radeonsi, raven, LLVM 19.1.1, DRM 3.59, 6.11.2-amd64)
GL_VERSION: 4.6 (Compatibility Profile) Mesa 24.2.4-1
Surface Config: buf=32 r=8 g=8 b=8 a=8 depth=24 stencil=0 samples=0
Surface Size: 800x600 windowed
[build] use-vbo=false: FPS: 6462 FrameTime: 0.155 ms
[build] use-vbo=true: FPS: 7396 FrameTime: 0.135 ms
[texture] texture-filter=nearest: FPS: 7213 FrameTime: 0.139 ms
[texture] texture-filter=linear: FPS: 7076 FrameTime: 0.141 ms
[texture] texture-filter=mipmap: FPS: 6894 FrameTime: 0.145 ms
[shading] shading=gouraud: FPS: 6559 FrameTime: 0.152 ms
[shading] shading=blinn-phong-inf: FPS: 6549 FrameTime: 0.153 ms
[shading] shading=phong: FPS: 6433 FrameTime: 0.155 ms
[shading] shading=cel: FPS: 6237 FrameTime: 0.160 ms
[bump] bump-render=high-poly: FPS: 4661 FrameTime: 0.215 ms
[bump] bump-render=normals: FPS: 7041 FrameTime: 0.142 ms
[bump] bump-render=height: FPS: 6800 FrameTime: 0.147 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 5754 FrameTime: 0.174 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 3723 FrameTime: 0.269 ms
[pulsar] light=false:quads=5:texture=false: FPS: 6420 FrameTime: 0.156 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 3036 FrameTime: 0.329 ms
[desktop] effect=shadow:windows=4: FPS: 4660 FrameTime: 0.215 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 1206 FrameTime: 0.830 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 1671 FrameTime: 0.599 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 1368 FrameTime: 0.731 ms
[ideas] speed=duration: FPS: 3147 FrameTime: 0.318 ms
[jellyfish] <default>: FPS: 4691 FrameTime: 0.213 ms
[terrain] <default>: FPS: 465 FrameTime: 2.151 ms
[shadow] <default>: FPS: 5973 FrameTime: 0.167 ms
[refract] <default>: FPS: 639 FrameTime: 1.567 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 7140 FrameTime: 0.140 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 6918 FrameTime: 0.145 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 7090 FrameTime: 0.141 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 6884 FrameTime: 0.145 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 6835 FrameTime: 0.146 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 6903 FrameTime: 0.145 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 6757 FrameTime: 0.148 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 6808 FrameTime: 0.147 ms
glmark2 Score: 5375
% 7z b
7-Zip 24.08 (x64) : Copyright (c) 1999-2024 Igor Pavlov : 2024-08-11
64-bit locale=C.UTF-8 Threads:8 OPEN_MAX:1024
Compiler: ver:14.2.0 GCC 14.2.0 : SSE2
Linux : 6.11.2-amd64 : #1 SMP PREEMPT_DYNAMIC Debian 6.11.2-1 (2024-10-05) : x86_64
PageSize:4KB THP:always hwcap:2 hwcap2:2
(810F10)
1T CPU Freq (MHz): 3545 3708 3743 3750 3745 3743 3747
4T CPU Freq (MHz): 389% 3293 396% 3404
8T CPU Freq (MHz): 730% 2709 762% 2894
RAM size: 31026 MB, # CPU hardware threads: 8
RAM usage: 1779 MB, # Benchmark threads: 8
Compressing | Decompressing
Dict Speed Usage R/U Rating | Speed Usage R/U Rating
KiB/s % MIPS MIPS | KiB/s % MIPS MIPS
22: 22663 663 3324 22047 | 243376 793 2619 20753
23: 22070 680 3309 22487 | 237989 789 2610 20587
24: 21495 681 3394 23112 | 234581 793 2594 20582
25: 21525 683 3597 24577 | 224661 778 2570 19990
Avr: 21938 677 3406 23056 | 235152 788 2598 20478
Tot: 732 3002 21767
# cryptsetup benchmark
# Tests are approximate using memory only (no storage IO).
PBKDF2-sha1 1264868 iterations per second for 256-bit key
PBKDF2-sha256 2427259 iterations per second for 256-bit key
PBKDF2-sha512 1171593 iterations per second for 256-bit key
PBKDF2-ripemd160 633198 iterations per second for 256-bit key
PBKDF2-whirlpool 537731 iterations per second for 256-bit key
argon2i 4 iterations, 1048576 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
argon2id 4 iterations, 1048576 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
# Algorithm | Key | Encryption | Decryption
aes-cbc 128b 857.5 MiB/s 1732.1 MiB/s
serpent-cbc 128b 82.4 MiB/s 349.6 MiB/s
twofish-cbc 128b 171.9 MiB/s 348.0 MiB/s
aes-cbc 256b 758.5 MiB/s 1770.7 MiB/s
serpent-cbc 256b 100.7 MiB/s 350.8 MiB/s
twofish-cbc 256b 196.5 MiB/s 348.5 MiB/s
aes-xts 256b 2193.8 MiB/s 2199.3 MiB/s
serpent-xts 256b 295.8 MiB/s 323.3 MiB/s
twofish-xts 256b 316.6 MiB/s 323.3 MiB/s
aes-xts 512b 2028.7 MiB/s 2023.8 MiB/s
serpent-xts 512b 325.5 MiB/s 323.7 MiB/s
twofish-xts 512b 323.3 MiB/s 321.6 MiB/s
# hdparm -tT /dev/nvme0n1
/dev/nvme0n1:
Timing cached reads: 17152 MB in 1.98 seconds = 8669.59 MB/sec
Timing buffered disk reads: 3034 MB in 3.00 seconds = 1011.11 MB/sec
