Przekazuję do HackerSpace’u dongle’a Magic Reader V2.
Jest to ESP32-S2 z modułem Ebyte E07 (czyli radio CC1101), którym można m.in. czytać telegramy wmbus.
Poniżej YAML z konfiguracją, która pozwala skompilować ESPHome do niego:
dashboard_import:
package_import_url: github://MariuszWoszczynski/wmbus-reader-v2/wmbus-reader-v2.yaml@main
import_full_config: true
substitutions:
friendly_name: "wmbus reader v2"
status_led: GPIO15
esphome:
friendly_name: "${friendly_name}"
project:
version: "1.0"
# only for RPI
#compile_process_limit: 1
esp32:
board: lolin_s2_mini
framework:
type: arduino
external_components:
- source: github://SzczepanLeon/esphome-components@version_3
components: [ wmbus ]
refresh: 0d
time:
- platform: sntp
# Enable logging
logger:
level: debug
# Enable Home Assistant API
api:
encryption:
key: "D0KKR80TBX3z2sx+Pejf1BBJ/+jaj5dQZXNZuwD/s8k="
ota:
- platform: esphome
wifi:
ssid: "XXX"
password: "XXX"
output_power: 18dB
# static IP configuration (instead of data from the secret file)
# manual_ip:
# static_ip: 192.168.10.99
# gateway: 192.168.10.1
# subnet: 255.255.255.0
# Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "WMBUS Reader v2"
# password: "password_12345678"
# Status LED for connection
status_led:
pin:
# Blue LED
number: ${status_led}
captive_portal:
web_server:
port: 80
version: 3
wmbus:
mosi_pin: GPIO35
clk_pin: GPIO36
miso_pin: GPIO37
gdo2_pin: GPIO1
gdo0_pin: GPIO2
cs_pin: GPIO34
# log_unknown: true
text_sensor:
#diagnostic info
- platform: wifi_info
ip_address:
icon: mdi:wifi
ssid:
icon: mdi:wifi-strength-2
sensor: # ############## The following sensors are examples. Adapt the sensors to the meters you have (according to the instructions) and remove the others.############
# Reports the WiFi signal strength/RSSI in dB
- platform: wifi_signal
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
# first sensor (water)
- platform: wmbus
meter_id: 0x00000000
type: izar
add_prefix: false
lqi:
rssi:
total_water_m3:
name: "My cold water"
# filters: #optional
# - offset: 123.4567 #the difference between the indications of the radio overlay and the counter (if you have a used overlay)
last_month_total_water_m3:
name: "Last month total water"
current_month_total_water_l:
name: "Current month total water"
transmit_period_s:
name: "Transmit period [s]"
remaining_battery_life_y:
name: "Remaining battery life [Y]"
current_alarms:
previous_alarms:
# second sensor (water)
- platform: wmbus
type: apator162
add_prefix: false
key: "00000000000000000000000000000000"
lqi:
rssi:
total_water_m3:
# third sensor (gas)
- platform: wmbus
type: unismart
add_prefix: false
lqi:
rssi:
total_gas_m3:
# fourth sensor (electricity)
- platform: wmbus
type: amiplus
add_prefix: false
mode: T1C1
rssi:
total_energy_consumption_kwh:
name: "My consumption in kWh"
icon: "mdi:power-plug"
current_power_consumption_kw:
name: "My current power consumption in kW"
total_energy_production_kwh:
name: "My total energy production in kWh"
current_power_production_kw:
name: "My current power production in kW"
voltage_at_phase_1_v:
voltage_at_phase_2_v:
voltage_at_phase_3_v:
# more options on https://github.com/SzczepanLeon/esphome-components
