Lighting: DMX controller for LED moving head
Hi, guys!
Does anyone has experience with DMX512 protocol and/or a hardware?
I’ve bought some used noname LED moving head, very similar to “Betopper Spot light LS10”. It requires at least some cleanup, so I will probably bring it to the HS one of the Wednesdays evenings. It has DMX control port, but I don’t have any equipment to control it.
It would be nice to understand how DMX works before to buy/create something serious.
Maybe somebody has a DMX controller, or USB adapter or even experience how to work with them?
I have XLR cable and 2 Chinese USB-RS485 adapters. But, unfortunately, adapters have only 2 connectors: D+ and D-, no ground connector. Something like this one. If I understand correctly, I need minimum 3 wires for DMX512: GND, D+ and D-.
We can go to the music club we have next door (really!) and test it out there. If it works, there is a USB-RS485 dongle in 'space as well ;-]
Yesterday in the HackerSpace I’ve measured the device power consumption with the Voltcraft energy-logger 4000 FR, and it is surprisingly power hungry:
  • Idle (LED switched off): 22W / 48VA.
  • LED switched on, no movements: 60W / 112VA.
  • LED switched on, the head is moving: 70-75W / 132VA.
So it looks like the LED is not 10W, but 30W (for example, Fractal mini LED gobo spot 30W). Or, probably, it is a 10W LED with very bad power supply.
The universe decided I need a second moving head, so I couldn’t resist and bought this one for 120 zł (~$29). It has label “Lixada”, condition is worse: one “leg” plastic cover is damaged, one lens fall off (but it was inside). Also the head itself is not balanced about center of gravity. But it works!
I tried to connect both devices in master-slave mode, unsuccessfully. Probably because firmware are different, even menu is different.
Also I tried opensource DMX console QLC+, but it is not compatible (1, 2) with my USB RS-485 adapter (CH340/CH341) :frowning:
Ok, it is time to use professional DMX adapter and I’ve bought AVT USB - DMX512 PRO for 130 zł (~$32), made in Poland, with galvanic isolation.
Finally, everything works together! I can control both moving heads from QLC+! :star_struck: :man_dancing: :mirror_ball:
The third LED moving head: 12V power supply of noname LED moving head.
